- Jan 6, 2005
You may be tempering the edge back and making those final microns soft by not using some kind of coolant while you sharpen. I know some of you guys are going to laugh at that but it is true. Roman Landes did experiments by imbedding pyrometers into very thin cross sections of steel. Sharpening BY HAND on a dry stone saw edge temperature reaching over 1000F! What do you think that is doing to the steel? That is why I no longer use power equipment to set my edges or strop. I set my final bevels on watercooled stone or DMT plates. There is a noticeable difference.
A burr means you are either taking more material off than you need or are overheating/tempering the edge and deforming it. In fine grits, there should be no burr.
The geometry that works best for me is a shallow convex(almost flat) with a fine micro-bevel at around 12-15 degrees.
