There's nothing worse
Than hearing a blade go "tink" during the quench... :(
Not quite sure what I did wrong. But I guess it's back to the drawing board now.
Details would help.
Blade size, metal,quenchant,type of quench, how was it heated,etc.?
Stacy
It is indeed the most terrible sound a KM could hear .
How much effort went into this learning experience ?
I kept a cracked blade as a reminder :)
Just say no to water .
blade is 4 1/2" with a hidden tang
steel is 5160
heated in my propane forge (estimated temp, no thermometer)
oil quench after anneal and normalize
I suspect that I heated to too high a temp before the quench...
Make sure you don't have stress risers - as in anything that is not round/flowing but rather 90-degree-ish, sharp corners . Do you see where the crack started - most likely it did it at a stress riser point.
If you profile the "outline" with a 30-something-grit, the outer edge will have pretty deep scratches all around - these are also stress risers. 220 grit fixes that :)
One must agitate the part during the quench so it cools as uniformly as possible
