Can I infer from your statements that by cryo treating a knife made of 52100 I will see a 400+ % increase in the wear resistance (edge holding??) of said knife?
The Charpy comparison states that they are comparing their own independent Charpy test with the numbers from Crucible. The problem is, Crucible uses a Charpy C-notch, which is a notch they created/modified for their own purposes, as a Charpy V-notch (the standard), gives very low values for most tool steels; it's hard to compare toughness when all the values are between 1 and 2 ft. lbs. Anyway, I don't believe that they asked Crucible what the parameters of their test are, then tested it that way, yet they are comparing values. I'm having serious doubts that they did anything but make up the numbers. If they really did Charpy tests they would have just compared it with a standard heat treatment rather than using Crucible numbers. If a representative of the company will truthfully back up the numbers I'll reconsider, but for now I'm going to call BS.
Mike, when the deep cryogeneic treatment is done with the correct profile (meaning not a dunking in liquid nitrogen then whipped out again) 52100 will exhibit 400+% gains inb wear resistance. It has been proven in research papers under controlled conditions, and those research papers have been replicated by other people with repeatable results.
My real intent with spending the time in this thread was to see what profiles people are using, see if anyone knew anything about this thermacycle patent pending process and to expand my knowledge of what profiles are being used.
After many phone calls to shops in my country and digging through papers the one profile accessible to me is a slow progressive 24 hour cool down, 24 hour at -310F and then 24 hours back to ambient temps. Its the only one the shop was prepared to do in my area. Im trying to identify other profiles and better understand what might be an optimal set of heat treating and deep cryogenic treatment for 52100 blades.
If any of you are serious about true high performance knives then I am convinced more collabaoration is needed between us enthusiasts if we want to match the professional companies. Afterall, anyone can buy a given grade of steel as raw material......the difference between poop and poetry comes in processing.
Will your lack of courtesy is ugly and unnecessary.
Perhaps I did not express it very well. It just seems to me that busse and bark river and all the rest for obvious reasons dont want to collaborate on their process. Therefore the enthusiasts are left to themselves in that sense and thats why collaboration is important. Its a general comment thats not restricted to cyro, its about the whole processing of steel.
I have not even finished my tests so I dont have any results or conclusions of my own.
I'll quote Busse and Mike Stewart.Im tempted to label this an appeal to authority rather than a rational statement but instead
