- Jun 20, 2007
From a post on the forum.
http://www.bladeforums.com/forums/showthread.php?t=635924
The post talks about using a thermoucouple and PID with the potential for a trmperature regulated forge.
"This thermocouple might be better suited as it has a higher working range up to 2300F which will easily be seen in most forge situations. You'll also want to look into a protective cover as fuel exposure can easily shorten the life of the probe. Here's the cover for the above TC.
This PID would work great for a simple pyrometer reading, and it also has the potential to be used as a solenoid controller in the future if you decide you want a temperature regulated forge."
My question is this on a forge like mine and here are pics of my forge,
Where would be the best place to locate the thermocouple?
Would it be better to penetrate the top, side, bottom of the forge with the thermocouple or just lay in on the firebrick on the bottom to get a true reading on temps? I am trying to think ahead before I put the inswool in and the fire brick on the bottom for how the thermocouple is going to need to be routed to where is picks up the heat.
Any suggestions from someone who has a similar set up?
