- Jun 20, 2007
I am looking for an opinion as to the placement of my thermocouple in my forge to achive the most accurate reading.
This is my forge. Before the burners were installed and plumbing to them was run.
(click thumbnails for larger view)
The burners have been angled to create a vortex, the inside is lined with 2" of inswool and the bottom has a 1" layer of firebrick.
This is the thremocouple I will be using. It is incased in cermaic sleeve blocks.
I have notched the firebrick in the floor of the forge to allow for the TC to lay flush to the top of brick. The TC would be inserted thru a hole drilled in the side of the forge directly in the center between the two burners. In theroy it should be reading the temp at the firebrick floor of the forge, directly where the knife would be laying.
So how does that sound for placement as to getting an accurate reading?
Also is there a way to test the reading your PID is giving you inside of a forge? Perhaps a container of water and check the boiling point?
