Its far simpler if you just use the needle valve and the blower to adjust temps.... solenoid valves, in my experience do not work well on forges where your using the measurement of the air temp as the set point. The forge will cycles way too much, and in many instances, will not always re-light when the "call for heat" is sensed, which can be a dangerous situation. This can be correct by installing some kind of ignition system, but your adding more "things" to go wrong.
The solenoid valves work well on Salt tanks because you have a large thermal mass (the liquid salts) which do not cause the large and rapid temp fluctuations that air does.
My thought with a forge used for forging, is to keep it as simple as possible...it will generally work much better, and if something does go south, its much easier to track down the cause. In this case KISS is the best principle to follow.
