I think it is closer to a dozen. Mine is .375", which is about 9.3 mm. It's the green one:cjpgeyer said:I have an Off Duty custom shop that is nine mm wide. It DESTROYS! It is the biggest small knife you'll ever handle. I believe two were made, plus a prototype.
Rat Finkenstein said:What about the Dragon's Fang?
or. . . Why not be the first to custom order the biggest and most expensive Busse ever made? Go for it!
MVF said:I'm with the THINFI guys. I'd like to see Jerry offer both a HOG version and a thinner version of most blades. I know it's probably sacrilege to say it out loud, but the edge on a 1/4" blade is really too thick for maximum usefulness.
I'm surprised more people haven't asked for thinner blades. What's the point of having a steel as tough as INFI and still making the blades so thick that even an inferior steel would be plenty strong. Why not take advantage of INFI's quality to make thinner blades that are still more than strong enough for heavy use, but slice better too? If I could afford a custom Busse, that's what I would do.
MVF said:I know it's probably sacrilege to say it out loud, but the edge on a 1/4" blade is really too thick for maximum usefulness.
Progunner said:You have to go mighty damned big to beat the Chuckchete for size and expense!![]()
MVF said:Cobalt, I'm not really following you there.I was thinking mainly of my FSH (convex grind)- which Busses are flat ground? I just wish the edge on my FSH was thinner because I think it would be all-around more efficient.
On the other hand, I don't know that I want my first adventure in re-profiling to be on the most expensive knife I own!![]()
Cobalt said:There is no convex ground Busse to my knowledge. This would entail putting the entire side of the knife to grind on a slack belt, not just the edge. All Busses are either Flat ground and sabre ground with convex edges and assymetrical edges.
Rat Finkenstein said:AFAIK, the SJTac has a convex primary grind.
Correct. There are a few Busse knives with hollow ground blades, but almost everything else is flat ground primary, either sabre or full. See below for an exception.Cobalt said:Also, most Busses are flat ground and the edge is a convex grind, like your FSH. I guess the difference is terminology. You say convex ground, you need to specify edge or blade.
