Thickest Knife
[1/2" 440C tougher than 1/4" INFI]
Cobalt said:
I wouldn't assume that ...
No, you don't gain much impact toughness with thicker stock, strength goes up rapidly fast, but not impact toughness and flexibility actually goes down.
But with Jurgens design it will not be in anyway an effective cutter at all. Getting it sharp after the factory edge wears off will be interesting as the blade angle is truly too thick.
David Boye had some massively thick blades, 1/3" thick at the spine, but they sharpened very easily and cut very well on a lot of materials because of the primary and secondary grinds. The spine thickness of a blade is only going to matter if the material actually "sees" it. If you are cutting 3/8" hemp for example, pretty much all that matters is the edge angle and in particular is most sensitive to the microbevel.
Not that I would argue for putting that kind of deep hollow grind on a 1/2" thick 440C blade, or even that thickness in that steel in any grind, that is definately a case for a shock steel, or at least one of the spring or high impact A series steels. Imagine chopping heavy with that blade and hitting something hard with all the weight and speed of that massive heft behind it and having the edge unsupported by a hollow grind.
Quiet Storm said:
The rule of thumb is as follows: the better a steel holds an edge, the more brittle it is.
There are lots of types of cutting where edge holding increases with toughness, wood chopping for example. Now often to gain wear resistance you have to trade impact toughness, but edge holding doesn't always correlate well to wear resistance and even even this relationship is broken readily, CPM grades can have better toughness and wear resistance at the same time due to more homogenous structure for example as can changes in carbide structure which reduce aggregation and increase individual carbide hardness (Cr to vanadium for example).
As for being the "best", someone has to, just define the characteristics used to judge performance and their weights, then they can be measured and values assigned, people do it all the time, every single day. Of course everyone is free to chose what they think is important and just how important each aspect is to them.
-Cliff
Quiet Storm said:
It's a rule of thumb - nothing more, nothing less.
that is a good rule of thumb, but you had to realize that Cliff was going to give a couple of paragraphs on it:eek:
Cliff, lets say Benchmades aus8a holds an edge longer than Kershaws aus8a, what would that mean to you without any other data. That one is set at a higher Rc maybe which means it is more brittle. So in general that is a goo rule of thumb. Of course different steels have different resistance to wear which means they can hold an edge longer or less with no change in hardness, but if the steel is of the same type, then the higher Rc makes it more brittle usually and that is a good simple rule of thumb.
Quitestorm,
how's that nasty looking tanto working for you. I would love to see some more picks.:thumbup:
Cobalt said:
... lets say Benchmades aus8a holds an edge longer than Kershaws aus8a, what would that mean to you without any other data.
Nothing, I would have to know what was cut and how. Edge retention correlates to hardness, toughness, wear resistance, grain size and corrosion resistance how strongly on each depends on the method used in the cutting and the nature of the media.
A higher hardness does not always mean less toughness, when tempering steels there are a number of competing reactions taking place :
-martensite loses carbon to transition carbide
-retained austenite transforms (bainite / martensite / pearlite)
-cementite forms
-martensite changes from tetragonal to BCC
-alloy carbides form
Some of these raise hardness and strength, some increase wear resistance, some increase toughness and others do the opposite on all three. It is possible to increase hardness, toughness and wear resistance all at the same time or to lose multiple at the same time as well. The toughness curves for steels are not simply linear, they are highly peaked, some actually have multiple maxima like A2. In fact none of the cutlery steels has this simple linear behavior, even the strength/toughness dependance on HRC of the plain carbon steels is highly contorted.
This rule of thumb probably dates back to the introduction of tempering which is often regarded as a softening step to increase toughness which is how many makers still view it and promote it, however that is not what is does. Tempering is done to change in a metastable crystal structure (martensite) to a more stable one and allow adjustement of the various steel properties. You can increase hardness and strength in tempering just as easily as you can decrease it.
-Cliff
Cobalt said:
Quitestorm,
Hi Cobalt!
I haven't used it all that much so far - not because I'm afraid of scratches ( ;) ) but because I decided to put this one into my bug-out bag.
Oh, did I mention its also made of S7 tool steel? :D
You also forgot to mention that this thread is 4 1/2 years old...:p
ETA: I know that Busse was already brought up but not sure if the MOAB at around .40" was mentioned.
Holy necrothreads batman. Here comes another one of them out of nowhere.
oops, this was one of the first blade forums threads to come up when I searched "thickest knife" on google so I thought it was fairly recent, didnt even look at the dates
The Ranger Signature series in S7 should eventually have other models. The 4 thru 6 inch models feel kind of like railroad spikes. With good grips of course.
It is nice to see production S7 knives back on the market.
Theres a user on here who has a neck knife made out of 1/2" stock. Can't remember the name though... You can probably find it if you browse a few neck knife threads.
