I do like this idea! There are, I believe, printed circuit boards for various electronics...(use them with or with out the capacitors/resistorsDay late on this but I'm dreaming of you etching circuits into those board first.
The neat thing is with a few of the right things you can draw your own board and etch it. So if you really want custom you come up with a neat package. I don't think it would respond well to sanding so you'd have to get a bit tricky but I bet it would be doable.You done good! Very creative and well done!
I do like this idea! There are, I believe, printed circuit boards for various electronics...(use them with or with out the capacitors/resistors) Preston
View attachment 969863 You can put that knife together with screw sets. The barrels are 1/8” diameter. The internal threading is #2X56TPI. The barrels and screws come in various lengths. If you have to shorten a barrel and/or a screw, put the ragged ends together with red Loctite to turn the assembly into a T-nut. When using a T-nut assembled in this fashion, 2 screw driver bits will be required to assemble and disassemble the knife, but only one screw will be removeable.
Looks great what is the weight of the knife after modification?
