I heat treated two AEB-L blades yesterday, one 0.04" thick, the other 0.082". Both were only profiled and about 11" or so long. I did a prequench after twenty minutes at 1,725F and then 1,975F for ten minutes. Both blades seemed to bend under their own weight on the way from oven to quench plates. The thinner blade curled up at the ends shortly after I put it on the bottom quench plate and before I put the top plate on, the ends were about 1/2" off the bottom plate. I quenched the blades separately and left them between the plates for two minutes. The thicker blade was at 70F, the thinner one at 100F after that amount of time. I think the folds of the foil packet in the corners were actually thicker than the blade itself and I did not have good contact everywhere because of that. After plate quenching, I removed the blades from the foil packet and put them in a dry ice/denatured alcohol bath.
Both blades were pretty warped, so I clamped them to a piece of angle iron and tempered for two hours at 350F. The warp did not get noticeably better, so I shimmed and over-corrected the warp when clamping and tempered again at the same temperature for another two hours. This appeared to have helped a little bit, particularly on the thinner blade. The thicker blade is in the tempering oven again with a bit more aggressive correction applied.
Am I wasting my time trying to straighten the blades this way? Is there a better way to straighten them?
I want to cut out a few more blanks and try this again, but I am not exactly sure what I need to do differently to get better results. I did not have the quench plates mounted in a vise and just used my body weight. Next time, I will try the vise. How hard do I need to squeeze?
When sealing the foil packet, how many times do I need to fold the edges? I folded three times and the blades came out pretty clean, but I think the folds prevent the quench blade from making good contact with the thinner blade. Also, the foil stuck a little bit to one of the blades. Is there any way to prevent this?
Is there anything else I can do to minimize warping?
