- May 7, 2015
Has anyone had this problem?
I'll rough grind the bevel at about 60 grit with a Norton Blaze belt. No problems so far, all the small grit lines are unbroken and the bevel looks satisfyingly flat. Repeat process with norton blaze 120, still good.
After i heat treat, i try to bring it up to 220 with a J flex belt and i see the grit lines break up in weird, wavy broken patterns. I'm beginning to hate j flex belts for this reason. usually i put a 320 Bluefire on after this (a thicker belt) and it straightens the bevel noticeably, or at least if i come to that belt with a straight bevel, it maintains it.
Am i using the J-flex at the wrong time in the process? I can feel the seam of the belt bumping under the knife as i push into the platen and i swear it's messing me up and giving me problems when going into the higher grits. I don't know if it's because of the belts im using or if its my technique.
The higher the grit i go, the harder it is to seemingly maintain a flat bevel. Is it just revealing mistakes I'm making earlier on?
Super confused.
Super confused.
