A few years ago when I first got "into" knives, I got a Victorinox One Hand Trailmaster (Trekker now) and after reading the review ....AND.... succumbing to my own ignorant prejudice from the way MOST knives were, I removed the serrations. I also skinnied the blade down to sorta Delica profile.
This week I got ANOTHER Vic SAK One Hand TREKKER and am leaving it alone.
When I removed the serrations on the first one, I did not pay any attention to the nice chisel grind on the original and I profiled it in a V-edge.
The new one works SO much better. (As the old one would have if I had let it alone)
BUT..... they have it RIGHT with the serrations on the FRONT of the blade. My Delica full serrated educated me to the advantages of a serrated rather than plain blade. However, plain is also useful.
And WHERE do you use the plain edge the most? Sharpen a pencil. Strip a wire. Whittle a stick. Do a pull cut. And WHERE on the blade is that usually done? Near the HAND....for control.
And what if you happen to cut something on a hard surface like a plate or tile or whatever? With serrations on the TIP of the blade, the peenty points take the friction and the edge doesn't go away.
And where do you NEED serrations? When you're REACHING to cut something with minimum effort. Cutting a line, a seatbelt, netting, etc. Having the AGGRESSIVE part of the edge at the FARTHEST arc of the knife makes more sense.
So I hereby announce the changing of my mind and the DEnouncement of the serrations at the back part of the edge.
RIGHT? WRONG? (check prejudice at door and consider)
