I thought long and hard before responding to this thread. Implying one should depend on a Bic lighter is treading on thin ice and could get people in trouble fast, or worse.
Between the cold wet winters and the trips that I took down the river, there is one thing I know for sure. Don't depend on BIC to get you out of trouble. I have had them fail because they were wet, such as a man in the creek dril, or even just a little water on the flint from rain or wet hands. Without something else to light the gas you're waiting for hours in the cold. I've also had them not work at all while out deer hunting because they lost pressure due to how cold it was out. I can't think of a time that I got in trouble depending on a BIC that a ferro rod would not have been a welcome site.
As explained in this thread the issue was not the rod. The ferro rod did as it should have, it started the fire for you. The failure came from prep and material selection, which you learned quickly and went to look for fatwood. You could have started that same fire using your rod. You could also have carried waxed cotton which will burn for 20 minutes and dry your shavings and thinner than pencle material. The bottom line is this shows how important it is to go out and pratice so you know when to look for fatwood, split wood, and doing the prep proper. You may only get one shot at a fire when you need it most. Take you BIC if you must, but also have three or four other methods available. In this case carrying dry tender out have helps too, be it fatwood, shavings, or whatever. The ferro started the fire just fine, it was what happened before and after that caused the issue.
