This is my canoe. There are many like it, but this one is mine - outfitting
These pics are great and I love seeing this rebuild/modification. This is incentive to start a project of my own. I have recently made a few changes to my kayak but thats small potatoes compared to this. Thanks for the run down.
This really isn't that big of a project. I actually spent more time stripping out old parts, glue and bits of foam than installing the new outfitting. And as mentioned, I still have some adjusting to do to the seat and thwart positions. The test paddle today proved that I got the seat height correct (for me) the first time, so I won't need to trim the drop plates again. I just need to shift the seat foreward a bit and shift the center thwart foreward a bit more than that. And add the painter ropes (I really missed having them today).
"If I had it all to do over", one thing I would change is the cage lacing d-rings. I would go ahead and spend the money for better metal ones rather than buying them with the kit like I did. We are all familiar with the problem of buying from internet pictures. The d-rings in the kit turned out to be the co-molded nylon "sew in" type, rather lightweight in my mind for riveting to the gunnels even though I did use reenforcing washers.
A do-over would use metal d-rings in metal tabs. I think I would also make my own heavier duty cage straps rather than using the ones from the Northwater kit. Both of those components will suffice, but don't, in my opinion, match the heavy duty hull and outfitting. I may replace them sooner rather than later.
Beautiful work.
I've been thinking about outfitting my Bell Morningstar with some float bags because I used to use her as a solo canoe. Never could come to grips with the garishly-bright bag colors, though. It would be really nice to have something in there in case I flipped, but I really don't paddle enough to warrant it. One bum knee sure takes a lot of fun out of the day!
Beautiful work.
Only the yellow ones remain readily available on the market, of the bright colors, at least in the U.S. I am having a hard time finding a matching red center bag for my canoe. The silver/gray and light blue vinyl ones are very available though. One thing to consider about installing bags... you really shouldn't store and transport your canoe with them in. Mine come right out by unsnapping the center strap buckle and deflating them. Then I can put them up in the house to protect them from rodents and other critters. The only problem with removing/reinstalling is that one needs a way to reinflate them, other than by huffing and puffing. I use a shop vac here at home and have to be careful not to overinflate. In fact, they should be left a little slack to allow for heat expansion, particularly dark colors like mine.
If you don't need a whole lot of flotation (my composite Morningstar has built in air tanks), a popular alternative to bags is closed cell foam. It can be found with peel-n-stick backing even. The main reason to install bags is to lessen the likelyhood of a serious pin in an upset in swifter water, and make recovery easier. For really serious whitewater, my Sunburst should have a pair of 60" solo bags like some of my earlier illustrations, not the shorter tandem bags I installed.
There are several otehr alternatives I saw while researching options. One is to use dunnage bags used to cushion cargo in trucks. Another is to use an inflatable gym ball. Like those giant play balls seen at Walmart, but heavier duty. Both are less expensive and easily removable.
It goes without saying (but I will say anyway) that the more water you displace (prevent from entering) an overturned canoe, the easier the recovery will be. After paddling my Bell a bit, I decided that the air tanks would suffice for that one considering my intended use. On both of my Old Towns I removed the blow molded factory seats for more comfortable ones and now they both depend solely on hull flotation. The Sunburst I intend to use of faster water where a swamping/upset/pin is a stronger possibility, thus my addition of the air bags, even though the Royalex hull has an ABS foam core. Whetehr I add a center bag or not, I will usually be carrying one or two Seal Line Baja dry bags strapped in as well, and they will exclude even more water and augment flotation. I don't intend to do steep creeking or go over waterfalls, so no need to go overboard and outfit it like a modern playboat, all airbag except a cramped, foam filled cockpit area for the paddler.
I had similar issues when I redid all the deck rigging on my boat, I bought a kit and as a result all of the pad ties are nylon. The upside is that the mounting hardware is stainless and the grommets are superior to ones I've used in the past. I think I'm goin to switch to steel next season.
It's a beautiful river that's for sure.
I hope to do more canoeing in the future. Thanks for the information!
JTC, I don't have many current pictures of the river. My camera battery died on me part way through this trip. Here is one more thoughm just showing a bit of the strata revealed along the river.
I did get the seat moved 3" and the thwart moved 6" foreward this morning. I may yet add a few pad eyes and a floor cargo d-ring pad or two today. And be ready for a second shakedown cruise next weekend with Jake and gear onboard. I'll try to get a better picture of the completed outfitting if I can coax my camera to work without charging. The charge cord is MIA. Oh, and I found a post from a Canadian forum which confirmed my suspicions about the rocker. 3 1/2".
ETA: The expected storm blew in and I moved the canoe to the covered front porch. Sitting flat on the concrete porch, the 3 1/2" rocker is very apparent... a 2x4 will fit on edge under each end with the center of the canoe still on the concrete!
I did get pad eyes installed in each section and a bungee paddle-park installed under the middle thwart. But the kneeling pads are a no-go. My knees just won't bend like that now, with my heels to my butt. So I'll find a home for them with a needy paddler. 2 1/2" of rain since just after noon today and still raining. I may need that canoe on the porch!
ETA: Readying the canoe for a trip this morning, the first two d-ring failures occured while inflating the airbags. They ripped out of the rivets with not a lot of stress, certainly not as much as they could be expected to endure in an upset on whitewater. So back on the rack she goes while Jake and I take the Old Town Guide on this overnighter. I'll search for the heavier cuty metal tabbed D-rings next beek. And buy another package of rivets and washers.
