- Sep 1, 2006
For whatever reason Dwaine Carrillo's work is very polarizing. A year or so ago I fell on the "love it" side and have been keeping an eye out for a SKOR-PIN folder from his TORK-NVTR 2 series (specifically, non-flipper).
Last week I managed to pick up a model 5 directly from Dwaine within a few minutes of him posting it for sale.
Dwaine is excellent to deal with and ships very quickly. :thumbup: The knife comes packed in the pictured Pelican case which incites a few chuckles upon opening.
Here are some specs, lifted from Dwaine's site:
Model: SKOR-PIN model 5
Blade material: 154 CM
Blade thickness: 0.27"
Blade length: 3.25"
Frame material: Titanium
Frame thickness: 0.19"
Grip material: G-10
Spacer material: T6061
Thumbstuds: Socket head caps
Clip material: Titanium
Closed length: 5.00"
Open length: 8.00"
After some struggle with the tight clip I managed to put this one in my pocket. It doesn't "disappear" but neither is it horribly obtrusive. I'd definitely say my Severtech is more annoying in the pocket--it's longer and more like a 2x4 with a clip.
Pulling the SKOR-PIN from the pocket must be done carefully. That tight clip and the various protrusions will lead to pocket damage over time. Of course most of my jeans' pockets are ripped up already from the aforementioned Severtech...
The general shaping of the knife is somewhat reminiscent of the Lum Chinese folder or the Whale Shark format (sadly I do not remember who to credit with that design). This makes it reasonably comfortable in the hand. Naturally with all of those angles there are a few areas that may become hotspots with extended usage.
The blade is surprisingly (shaving) sharp despite its thickness. The hollow grinds are quite deep and the secondary bevels are slightly hollow ground as well. Obviously you wouldn't want to slice tomatoes with it but it is a serviceable cutter. Lockup is of course solid. The detent is very positive and the opening action while not smooth isn't gritty. It's just very tight. I used to have a Trident (Crusader Forge) VIS-01T which was much tougher to open and close.
While this will probably rarely be an EDC, I suspect if I had to bring one folding knife with me into Armageddon, this would be it.
Blade length: 3.25"
Grip material: G-10
Open length: 8.00"
