I don't think that the ZT knives have names like the Kershaws do, so it would have to be assigned a number...Something like ZT 0201.so does that baby have a name yet?![]()
Ummm,.....just thought i'd ask,........you're not sending it back because the assisted opening is not working,........???
............because it doesn't work on any of them!!!!
Perhaps you're wanting a "Baby" ZT 0200?![]()
Mine has an off-center blade when closed and it has some wobble when open that I cannot correct. When I tighten the blade enough to be stable you can barely open the knife with both hands and LOT of effort.
Had the same issue with a Lahar and Kershaw sent me a new one that arrived this week. That one is a tad off-center still, but opens smooth and locks tight. The two JYD II's I have were perfect out of the box. I guess that's the luck of the draw when buying over the 'net.
At first I thought I might just return the ZT to the Pharmacy and buy later when the bugs are worked out, but then read that these are a limited run. Is that right? With that in mind I thought I would send it home to Kershaw for a fix.
Seems like a great knife, but for north of $100 it's a drag to have these issues out of the box.
I must say this can't be a common problem with these,.....as the 19 i've had were all centered very well, (with a good range of serial numbers under 1000 so far).....and all but two opened easily.
.....yours just was the uncommon exception, IMO.
I just bought a ZT200 plain blade with the serial #5966 from the Kershaw GuyThomas,.....on the admittedly small sampling (19) of the ZT 0200 and ZT 0200ST i've had to pleasure to own & examine,......i couldn't help but notice none had a serial number over 1,000. The sample of ZT 0200 i'm using as an EDC is number 0932,......about the highest numbered one i recall in my group. My ZT 0200ST is number 0478 , and both selected by me for a noticable extra bit of spring in the liner lock, and both lined up pretty near center in the blade.
But as none of my examples breached the 1,000 piece mark,.....i was a bit curious as to whether this run of ZT 0200's ended at just 1,000 pieces each of both the plain blade and partially serrated versions.
BTW,....all of my samples were made in July of '07
If these were limited to 1,000 pieces each,.....it would seem a very small number considering their intended market of police, military, emt's, fireman, and folks like me appreciating a top notch and useful product.
I suspect you do subsequent runs of various models based on inventory levels and demand,........so just a bit curious what inventory level you drop to before another "batch" comes down the line?
BTW,.....if any of this is beyond your's or KAI's desire to "share" with us,.....i understand. Never want to poke my nose where it doesn't belong.![]()
Why is that?I appreciate seeing the latest number.
Why is that?
Curiosity? I like random, trivial facts? Something along those lines.
