- Dec 23, 2010
Thorogood "The Duece" Tactical Boots Mens Waterproof Leather Side Zip CT Black 804-6191 Size 13W.
These boots are like new w/o box $old
Protective Toe
Impact testing determines the amount of protection to the toe under various foot pounds of force. Compression testing determines the amount of static pressure a steel/composite toe cap can withstand. Our boots are I75/C75
Electrical Hazard
Footwear is built with nail-free construction to help insulate you from the ground to retard conduction, but is not intended to be primary protection against electric shock. Leather footwear must be dry. Our electrical hazard boots meet and exceed ASTM electrical hazard standards.
Waterproof
This product is built with quality waterproofing materials to keep you dry in wet environments.
CSA Approved Soles that provide electric shock resistance
Soles that provide electric shock resistance. Such certified footwear contains a sole and heel design assembly that, at the point of manufacturing, has electrical insulating properties.
Non-metallic
Constructed using no metal material or parts. Perfect for working environments that require passing through metal detectors.
- Non-metallic
- Light and flexible cement construction
- ASTM F2413 protective toe classification
- ASTM F2413 electrical hazard standard
- Moisture-wicking mesh lining
- Leather and mesh upper
- Bloodborne pathogen resistant
- Contoured removable polyurethane insole
- Composite shank
- Heavy-duty YKK side zipper
- Thoro>dri™ WATERPROOF system
- Unisex styles come in men's sizes
- 8 Inches in height
- CAN/CSA Z195-02 CERTIFIED
- Slip-resistant rubber/EVA outsole
- Weight: 4.7 pounds per pair for a size 10
Protective Toe
Electrical Hazard
Waterproof
Non-metallic
