Thought on SK-5 steel
1080 can have up to 0.88% C
Neither Cold Steel nor any heat treatment method has anything to do with the name SK-5. SKD11 is another name for D2, doesn't matter how you heat it.
Carbon V was 50100B/0170-6C. Camillus probably did the CS blades the same as the Beckers and pretty much every other knife made of this steel. There really wouldn't be a need for separate heat treats from one factory for one steel on a similar fixed blades. Who knows how flexible the Taiwan factories are in processing the steels.
No Hardheart -- you got it backwards. The old JIS name for AISI 1080 was SK-5 -- or, rather, they allowed Americans importing steel to call their AISI SK-5 -- but the AISI regulations would not let you sell SK-5 of the sort that you saw on that spectrometer readout as 1080; AISI allows for between .75 and .88 carbon in steels sold as 1080 -- but that SK-5 was clocking in at at least .9 (it looked a little higher than that to me -- if anything it is more typical of 1090 melt).
The SK-5 shown does look like it meets the limits on S, P and Mn for AISI 1080 -- but AISI does not list a range for the max Si you can put in an alloy. I'd think that you'd have to call something other than 1080 if it had a composition like that...and you'd probably want to...you would get a cleaner melt with less oxidization because of the Si. You'd also avoid case-hardening the piece after quenching because the Si in that range is a good ferrite strengthener.
Edit: Also -- the particular 420HC heat treatment I was referring to involved a well-thought-out cryogenic treatment; as with everything, I imagine that the good stuff costs a little more -- not everyone wants it -- and some people pay more to get the better HT.
Edit 2: Okay here is the final scoop -- JiS lists the typical carbon range for SK-5 as between .8 and .9 -- and the typical Si content as .35. This makes SK-5 most similar to 1086 -- which is between .8 and .93 C -- and a Si range (if it has any) of between .15 and .30.
So, basically -- SK-5 is most similar to 1086 with a dash of Si that AISI deems worth our taking note of...
What did I get backwards? I looked in my ASM Heat Treater's Guide, and on page 204, it says 0.75-0.88 C for 1080.
JIS let you call anything with .8-.9 carbon SK-5; but you can't call SK-5 AISI 1080 because it has too much Si.
The carbon range for 1080 is .75 to .88 -- and the Si range maxes out at .3 (though you don't NEED any at all to have 10xx).
The carbon range for SK-5 is .8-.9 -- and the industry standard is to have .35 Si -- but they aren't as anal about calling high Si melts of AISI alloys within the .8 to .9 C range SK-5.
Despite this -- we are aren't 'nice enough' to label their steel by our name.
.35 Si is a little too high to be an AISI standard carbon steel. And the carbon range of SK-5 is more typical of 1086 melts than 1080 melts.
Not a big deal...but this seemed to be a cause of confusion before.
All the sources I have seen list SK-5 as AISI 1080 equivalent. Japanese or US or any other steel name crossreference table.
As far as I have seen no AISI source had Si specified for 10xx series. Where do you get the 0.3 Si from?
It(SK5) sure gets listed as 1080 all over the place.
Okay...I'm sorry if it came off like I was trying to start stuff with you guys. I like your posts, and regret it if I'm coming off like a punk. I found one manufacturer that listed their Si content for SK-5 as .35 -- the range for Si in SK-5 seems to be .15-.35 according to JiS standards.
Here's the clearest table I could find in the public domain; thanks to the Tenhiko Corporation:
http://www.tenhiko.com/search/zairyou/tokushukou/tanso.html
US standards for Si content seem to allow for between .15-.30; that isn't a requirement on 10xx alloys -- to clear up confusion -- that's just the level of Si you see in Si-killed rather than Si-alloyed steels; by the same logic they'd probably list max Al content at .005 -- the level you find when Al is added as a deoxidizer -- but, I mean, that's really a fairly minuscule amount -- they probably don't list it because it's probably not the sort of thing you're going to detect unless you are looking for it in specific...
