- May 30, 2013
What are your thoughts on 8Cr13MoV Stainless steel used by Kershaw and Byrd? It doesn't hold an edge quite as well as I would like it.
I have no experience with Kershaw's 8Cr13Mov, but I've used a Spyderco Mule and a Tenacious with that steel. It's OK, pretty similar to Buck's 420HC in performance (at least in my use). It's fine for an affordable EDC knife, it's super easy to sharpen and polishes up nicely. Edge holding isn't that great, so you might not enjoy it if long cutting chores are part of your daily routine.
ok nutnfancy...your mileage may vary dude
I do prefer it over aus8 used in some other name brand folders, Its almost like there was no heat treat on the blades in those Aus 8's and I'm not a picky person.
If its bead blasted at you live by a lake in Minnesota... You may have rust issues
i believe the Mule is actually 9cr18yaddayadda not 8cr. The Mule should hold an edge a little better if heat treated properly. I have two of those Mules but have hardly used them because no sheath or handles, have used my Tenacious a lot and it performed admirably for its price. Needs to be touched up often, but that's to be expected.
