- Mar 8, 2008
Lots of misconceptions being stated here. Chisel grinds are no different than conventional grinds, except that they're essentially skewed until one side is brought parallel with the center axis of the blade. Because of this, they actually tend to put a lot of side-load on the edge apex and so tend to roll a bit easier than double-bevel grinds of equal angle. They are best suited to paring tasks, like a...(you guessed it) chisel where the additional deflection caused by the geometry isn't a big issue. There are circumstances where chisel grinds make sense, but they are a specialty grind and not well-suited to general use compared to double bevels. If you're not making flush cuts you're unlikely to see a strong benefit from them.
