- Nov 29, 2010
This was to be my 2012 KITH knife. While drilling the weight reduction holes, I got close to the bottom of the tang. Real close. But I thought nothing about it because there was still metal left so I went about my business.
However, after gluing up the scales and finishing them and the bolsters, I decided it needed just a touch more taken off the bottom. I completely forgot about how close that one hole was. When a tiny black speck showed up after grinding, I thought it might have been a speck of epoxy so I laid it back on the grinder. The "speck" grew and I figured it was something on the belt so I cleaned it and tried to "grind the speck off" again. When the "speck" was larger I took my awl and tried to clean it. Only after the tip of the awl went into the "speck" did I realize what happened. It was such a disappointment because this was the first knife I tried metal bolsters on and I felt they turned out well for my first try. I have several friends who want this knife even with the hole and I'm thinking about giving it to one of them for Christmas.
My thoughts were to fill it either with JB Weld or Acraglas. I'm leaning toward Acraglas because I can warm it and it will get real thin. I then plan on using an old injector syringe to fill the 1/4" size reduction hole. I'm sure there will always be a "speck" there, just now it'll be filled with something. You thoughts on what you'd do?
