I've been putting this design together the last couple weeks and hope to start building soon. But before I start burning money, I thought I would run this past you guys since you'll have such a vast amount of experience with these things.
This will be a direct mount VFD driven grinder capable of vertical and horizontal grinding. Construction will be primarily 1/4" plate welded together. Other than supporting a direct mount motor and having multiple tooling slots, my main goal was to design something I thought I could actually build (I have metalworking and welding experience but no cnc equipment).
I didn't initially plan on having 5 tooling slots, but I wanted the midpoint of the platen to be at a certain height for comfortable grinding and the math just worked out that way. I could have left the space empty down there but then I would have had to add a brace anyway. So...why not?
Another mid-design idea I came up with was to put the gas spring on the wheel side of the frame. This gave me more room for the spring without having to increase the height of the tracking wheel...and allows me to run with the tension arm horizontal (not something I have seen much of when using a gas spring so far). I've checked clearance with multiple belt configurations and I'm pretty sure I've got enough clearance in all cases. I even have room to move the mounts around a bit (leaving that to a build time call). The gas spring isn't mounted exactly vertical so it will lose some of its force - but it is mounted further out than the wheel along the tension arm so that should help compensate for that. And I see advantages in mounting the gas spring on the same side of the tension bar as the tracking wheel: the twisting force caused by the gas spring should be offset by that incurred by the tracking wheel.
BTW, the slots you see on the side of the frame are for welding the side to the horizontal tool supports. This way you don't have to grind anything off from the other side where clearance is an issue. I'll probably add another row farther back - I just haven't put them in there yet.
Here's the backside showing the toolbar supports and braces that allow the whole thing to be flipped while still fully supported.
You can't see very well in this picture, but the mount for the tracking wheel is adjustable such that you can make sure it runs parallel to the frame (somebody's mod to the GIB I read around here...thx!). Handy in case something in the build process causes things to get out of alignment.
Here it is flipped horizontal. The motor doesn't clear without a cutout, but that was partly by design: In order to clear the table the belt would have been higher in the horizontal position than I wanted (like ~14" or so above the table with room for air to get into the fan). So to keep the height of the belt down I had to keep the flip point closer to the frame...which isn't high enough when vertical for the motor to clear. I plan on making a dedicated stand for this, so it wasn't a big deal to me.
...and yeah, I've calculated the belt lengths! I'm within 1" for both the platen and 8" wheel models...close enough for me to know it'll fit with slight movement of the toolbar!
And using the top tool support it should fit a 14" wheel without a problem.
Right now the length from the middle of the motor spindle to the front of the platen is about 24". Does this seem too "long" or about right? I could always raise the tension bar to shorten that if I need to.
If anyone sees any obvious gotchas or has any ideas I would love to hear them!
