Hair said:We are not talking about the same kind of strap- I can tell from the way you cut them- which is impossible for the type of strap I am refering to. The kind or strap I am talking about is about 1/4 thick and an inch wide and used to strap down pallats- sort of like metal bands, but it is plastic and joined by heat. I am sure your method of giving a rough edge to a portion of the blade works, but that portion is not as good at many types of cutting as the more polished portion of the blade, and so you have the same compromise as found on a combo edge. You just have a serrated portion that is better at slicing than a serrated blade, but not as good at sawing. So it is sort of like halfway between a plain edge and a combo edge. And while the method you describe is very useful, I think the combo edge compromise is just about perfect as I would rather have the two extremes rather than two shades of the same edge.
We are talking about the same straps. Theyre used to hold big ticket items like TVs, washing machines and grills to pallets. Generally theyre put on very tight and they are very tough to get off due to not being able to get under them. Smaller items generally use a double ziptie sized strap that is a little thicker but not as wide. Those are easy to defeat with this edge as well.
You've also missed the point of the post. You get to control the amount of edge realestate that is "serrated". If you only want a 1/2" you can do it. If you want more, you can do it. If you want to change, you can do it. With a combo edge you are stuck with what the factory gives you unless you're willing to put a lot of time and work into the edge and sacrifice a lot of possible blade material.
I've not found 1 thing that an actual serrated edge does better than a very coarse ground plain edge.
