The para is an awesome knife, if you can deal with tip-down carry.
The para is great, but some prefer a different carry position (para tip down rh only).
The tip [down] carry is not my preferred position but I've had it before and get used to it.
I have one of the D2 Paras, but don't carry it much. I think I'd like it a lot more if it came with a tip-up clip.
While it does not matter to me, I can understand some people having a preference for one or the other. What I don't really understand, however, the huge importance many people on the forum place on tip down vs tip up when chosing a knife.Tip-up is definately better.
I actually consider this a positive feature. As long as ultimate concealability is not a factor, I find having a slightly larger handle on a smaller blade gives a firmer grip and better control during cutting. :thumbup:The handle / blade ratio is also a bit out of proportion.
While some people have to look to the Para due to length restrictions on carry blades, I would agree that if this isn't a concern I would (and do!) chose the larger Millie. The larger blade and larger handle just make it that much better, IMO. While its true that some people may be more intimedated by the larger Millie, outside of the work environment as long as I'm "legal" I really don't care what some sheeple thinks of my carry blade.I tried to like the para - and I know ot is also a great knife, but the Millie is really much better IMHO.
I don't, I just mentioned some people find it a breaking point. I do prefer tip down carry.
I have a number of pocket clip knives in each orientation, and to be honest I'd have to go look at them to tell you which is which. It's just not something that I even notice while carrying and using a knife unless I stop to think about it. To me, tip orientation is a non-issue.
Again, as do I, but some people find it a problem.
The handle / blade ratio is also a bit out of proportion. I like this as I feel it increases control over the knife edge, but some find it not to their liking.
Wow...!
Just got my new Spyderco PE Para-Military in the limited run D2 with the green foliage handles. It's absolutely SWEEEEET.
Nicest EDC I've had to date. Came perfect out of the box. Blade centered, tight but butter smooth action with G-10 handles that grab you! Great balance and perfectly sized.
Still may get a Manix 2 but I will be hard pressed to find another EDC that I like as much as this thing.
Same here.
It's better to have a too large handle to blade ratio than the other way around.
