Someone who is in a position to know explained to me why GEC spring strength varies. He said the heat treatment is outsourced. This is a part of the process which they do not control. Apparently, heat treating can slightly change the dimensions of the material enough to cause varying spring strengths between runs. He said they test the first few knives of each run and can adjust their internal process, but if the heat treat caused the issue there is not much they can do about it. To me, this means that they do not intentionally adjust spring strength. Things just come out slightly different from run to run. I believe their heat treatment is done by Peters' which is a top notch company. GEC knives are very consistent between runs, but they can't always be identical.
