throw away your HI khukuris
Hi All,
First, Bill, I didn't know that there was a Barong in the works!! If so, since the project is a ways off yet... Add me to the list along with Smokey.
Now to the subject at hand. I bought both a CarbonV and a Stainless ATC (1/4") when they came out several years ago. This pre-dates the much newer LTC by several years. The blade design is something of a cross between a Khukuri and a Bolo, though it more closely resembles the Bolo. I sold the CarbonV knife and kept the SS version for the following reasons: 1) The rubber grip is great in subzero weather. 2) The stainless is either AUS-8 or AUS-6, both are tough enough to work in the cold without being brittle (like ATS-34). 3) The paddle shape of the fore section of the blade. 4) Points 1-3 combined with a flat grind make it a good snow knife. 5) Where I live and the weather gets to -20Degrees F. and below (hasn't happened much in the last few years) cutting fiberous material becomes quite a chore with heavy cloths and "choppers" on....it is also dangerous. The danger of having a blade hit the frozen wood and glance off to hit some body part that is much less resistant to a sharp edge is high, therefore, having a bldae that BITES in and sticks a little while up close is sometimes an advantage. An Axe head is more distant thus safer to use in the winter.
I as yet have not had the oppertunity to use any of my HI Khukuries in that kind of cold, so I can't comment for or against them under said applications, but in fairness to Cold Steel with the ATC I don't see HI K's replacing it any time soon as a snow knife. However, I must hasten to add that this may not apply to the Cold Steel Ghurka, much less any of the lite models.
Dan
ps. to anyone interested: the ATC is no longer made.
The ATC was the kukuri that got me interest in khukuri's. It was advertised as the silent chainsaw back then. Its weight of 1.5 LB caught my attention. I had just started using my knives (Ka bar size) for clearing limbs and found them too light.
I did not even know they made a stainless steel version of the ATC until Dan mentioned it. I wanted to get a ATC but it was not on the market long enough.
Will
