pistonsandgears
- Aug 12, 2011
Thrunite TN12 2016 model $35 shipped
Rear forward clicky switch (can do momentary on) for on/off side switch to cycle through modes
operates on 18650 lithium ion battery or 2 CR123
Light use, has a few dings, missing pocket clip
Cree XP-L LED 1050lm(90min) 800lm(1.5hour) 280lm(5hours) 20lm(74 hours) 0.3lm(1585hours)
Thrunite TN20 $38 shipped
Head rotates to 90 degree light
Magnetic base
Uses 18650 lithium ion battery or 2 CR123
Output mode/Runtime*: Strobe (770 lumens/340 minutes), Turbo (770 lumens/130 minutes), High (440 lumens/204 minutes), Medium (141 lumens/12 hrs ), Low (13 lumens/128 hrs), Firefly (0.24 lumens/69 days)
Light use, has a few small dings
Four Sevens Quark AA Turbo $sold
Uses 2 AA batteries
Light use, few small marks
Can program for any 2 of the following light settings..
Moonlight .2 -lumens = 30 Days
Low 4 -lumens = 5 Days
Medium 22-lumens = 2.4 Hours
High 85-lumens = 5 Hours
Max 205-lumens = 1.3 Hours
Strobe 2.5 Hours
Beacon 18 Hours
To set the 2 modes you want (Tight mode and loose mode)
Tighten and loosen 4 or more times and stop in either TIGHT OR LOOSE position (depending which position your going to SET)
You will get a FLASHING LIGHT confirming SET mode.
Cycle thru the choices and leave it on the choice you want for 10 seconds until flashing lights indicate successful SET.
J5 Hyper V $12 shipped (free if you purchase the TN12 or TN20)
Zoomable
Operates on one 18650 battery (body has some extra room around the battery, originally came with a battery adapter to use 3 AAA but that has been lost.
3 modes Low, High, Strobe
Thrunite T10T titanium flashlight $sold
rear clicky switch
XP-L LED (208lm), Low (13lm), Firefly (0.15lm)
operates on AA battery
Lightly used, comes with box and paperwork
Magnetic base
Uses 2 AA batteries
Strobe 2.5 Hours
Beacon 18 Hours
Zoomable
rear clicky switch
