Just letting a few lights go because they are not being used. Mostly a nightstander. It has a true firefly mode at 0.04lms. This one is cool white. Excellent condition. Small fuzz in 2nd pic, not scratch.
Very little use. Comes with all original packaging and accessories. Battery not included.
$35 shipped and PayPal’d
Factory specs:
LED: Cree XP-G2 R5, Cool White or Neutral White
Output mode: Firefly: 0.04Lm 100hours; Low: 11Lm 19hours; High: 255Lm 55min.
Uses 1*CR123 /1*RCR123/ 1*16340 battery
Max output: 255 lumens with XP-G2.
Working voltage: 0.9V-4.2V
Peak beam intensity: 2730ccd
Peak beam distance: 104m
Reverse polarity protection design to protect from improper battery installation.
Tail-switch and twisting head design.
Titanium alloy(TC4) body with surface treatment polishing process.
Toughened ultra-clear glass lens with anti-reflective coating.
OP reflector gives perfect flood.
Removable clip.
Stand on tail to serve as a candle, with the wand covered on the head.
Impact resistance: 1.5M
Waterproof: IPX8 (2M)
Dimensions: 80.5mm (Length) x 20.0mm (Diameter).
43g without battery
Factory specs:
Removable clip.
43g without battery
