- Apr 3, 2011
Has anyone thought about... A titanium insert instead of a steel one? Even if it wore eventually you could just pop another in
Has anyone thought about... A titanium insert instead of a steel one? Even if it wore eventually you could just pop another in![]()
Sure shiny, I'll play.You should call them up and offer your services, you'd be doing us all a favor. What is the proper geometry on the tang and lock bar?
Wow! A one year expert who has the secret some of the largest knife manufacturers need! Please contact ZT and educate them!Sure shiny, I'll play.
Assuming a dry steel on steel interface, you'd need about 8.5 degrees or less relative to the lockbar contact to have the lock function without slipping. This can be estimated using a static analysis of a ramped surface, where:
Force_reaction = force_applied * cos(tang_angle) & Force_friction = Force_reaction * friction_coefficient_static -> tang_angle = inv.tan(friction_coefficient_static).
Generally, the dry steel on steel friction coefficient is observed to be 0.15 as per experimental measurements. This gives a maximum tang angle relative to the lockbar of 8.5 degrees before slipping occurs; ideally you'd want less than this. This is generally in line with the usual recommendations of 7 to 8 degrees. At the very least this is a great starting point, and can be fine tweaked as needed depending on the specifics of your system.
Feel free to vehemently disagree with all of this as per usual; I have you on ignore anyway.
