Ti2 Sentinel X
Feedback: +57 / =0 / -0
The one on the right, Like new carried in the water bottle holder in my HPG tara three timeThe Ti2 Sentinel X is a no compromise, hard anodized, aluminum, lightweight, water-tight, large format cache for storing critical items and, in a pinch, can be used as a vessel over an open flame/heating source for water boiling/sterilizing.Internal dimensions* 2" diameter and 6" length (51mm x 153mm)External dimensions 2.5" diameter and 8" length (63mm x 204mm)Finish*-- Sentinel X1 Satin Finish is a bead blasted Type 3 Class 1 hard anodized coating that is food grade.* This anodizing process is typically used for military applications where durability is critical. *Also, this coating is common on aluminum cookware such as pots and frying pans offering excellent flame resistance.Water Tight*-- The “X” is tested water tight and features Twin orings for redundancy. *The orings are made from food grade silicone and able to withstand temperatures required to boil water.Strength*-- The “X” is strength optimized using CAD parasolid modeling resulting in a unique ribbed/skeletonized design. *We are using aircraft grade 6061-T6 aluminum in its construction.Lightweight*-- At just 400 grams the “X” offers a minimal weight footprint.* An excellent way to safe hold 18+ cubic inches (11 fluid ounces) of critical gear.Gear Integration*-- The design hosts 12 small slots for attaching a myriad of lanyards, paracord, clips, etc and one large loop for carbiners, larger straps, molle gear
$99 shipped in US
