- Dec 3, 1999
So normally when I cut mosaic tiles at a 45 degree angle and flip them, I just tack the edges with the wire feed, then wet weld.
Trying to broaden my skills, and having access to some really nice TIG units at school, I decided to try dry welding the latest billet.
I surface ground all edges and got everything to fit up darn near perfect.
Using a Thermal Arc 300 AMP machine, I did a fusion weld around all the joints with a very finely ground tungsten and around 120 AMPS. Ran a small puddle, fairly quickly.
This left a nice, clean, shallow bead. However, I tacked the edges first, then welded the seams on the face and some of the tacks pulled apart. I just went back over them, but I didn't like that too much.
I'm curious how you guys are doing it? Which unit, what kind of amperage, are you running the puddle very deep/wide? Fast travel speed?
How clean are you getting the pieces prior to TIG welding. I went so far as to clean the mating surfaces with acetone. Not sure if that's needed.
Any shared info would be greatly appreciated!
