Tightening small wheel radius on old Bader
My primary grinder is an original Bader bench model I bought new many years ago. It has gone through some evolution but still works well and I have just about any attachment I can use. Recently, I received a commission for a custom, full tang push dagger. When designing it, I realized that the small wheel attachment I use to clean up inside curves was not going to work due to the wide belt angle coming off the wheel. I know there are adapters out there that will bring that angle down but finding something for my old machine is almost impossible and I would have to significantly modify anything else I got to fit this machine. It can be done but would cost more than I could justify.
I happened to have a 2 inch contact wheel that I rarely use and decided I could take advantage of the extra tooling holes to mount it and pull the belt down. It turned out to be pretty simple (it helps to have a mill) and I am very satisfied with how it works. I did need to make it somewhat adjustable because it will affect belt tracking if it is not square to the system.
I don't know how applicable this might be to the newer grinders with square tooling holders but maybe it can help anybody out there with an original Bader.
Randy
Nice job. One of the machine makers handles this the way you did, maybe Wilmont. I have the USA Knifemaker small wheel attachment and though they have their own adapter that accomplishes the same thing, I think I prefer this approach.
Bob
When I saw the Wilmont idler wheel attached to the tooling arm, I too thought that was a great idea. I think that it can cause an issue with belt length if the wheel is placed to far back.let us know how the rubber wears. I thought that maybe using a typical platen idler would work well.
I did think about wheel wear as I was doing this. My conclusion was that as long as I have it set up so it is square to the belt, any sliding and slipping should be minimal. That's one of the reasons I made it somewhat adjustable in alignment. That said, I do see slight marking of the wheel after some use but it seems minor. Another factor would be belt grit size. Generally, I restrict my small wheel work to 220 or finer which should also help. I guess time will tell. A metal wheel would be better but this is what I had.
I had never seen the Wilmont but it is definitely the same basic setup, only using one tooling arm rather than two. I wonder what their experience is with wear?
Randy
