- May 28, 2007
I have read that the way these are engineered you don't have to worry about over tightening or adjusting the pivot like you do on many liner locks. I don't find this to be the case and was hoping to get your opinions and info. I put it back together and found that the pivot and blade stop screws need to be pretty loose or the action is WAY too tight. This makes me uncomfortable so I ended up using loctite. Now, I don't mean the screws aren't screwed in, I just mean I had to stop screwing them the second they get tight. Normally I feel more secure about screws not loosening if I can really tighten them. Any words of wisdom? Anyone else find the action gets to tight if over tightened? Anyone use loctite?
I have to say after taking the lanyard out and putting it back together, the action doesn't feel quite as perfect as it did originally. All the bushings and washers and everything are in the right place but the detent feels a bit more tight.
Thanks
Thanks
