- Jun 27, 2013
Hello all,
TimberGhost Custom Knives here with a TG Scout for sale. The Scout is a great EDC with a nice drop point blade profile. This particular one has our new sheath design. The new design features a removable insert that reveals a large cleaning slot. The insert is held in by three Chicago screws and when removed the cleaning slot is exposed allowing you to spray out and clean the inside of your sheath from dirt and abrasive materials. The Scout not only performs and looks great but its overall slim design has a very small footprint that carries nice. The insert on this Scout has a cool gear pattern and the sheath has many mounting options. Overall weight for this package sheath and all is only just over 6 ounces and the knife its self weighs 5 ounces. If you are interested the price tag is $250 and you can contact me here or at Timberghostcustomknives@gmail.com. Thanks for taking the time to check it out! Specs and pics below.
Knife Specs:
Blade:
Length: 3 1/8” (cutting edge) with sharpening notch 7 3/4” overall knife length
Thickness: 3/16"
Steel: This knife was made from D2 steel, hardened to 60 HRC and has a two tone acid stone washed blade
Grind: Full high "lean" convex grind with a secondary convex micro bevel
Swedge
Rounded tang and deep index finger choil for an extremely comfortable grip
Handle:
Length: 4 1/2”
Material: Ergonomic double black G10 that's been nicely contoured
1/4" Lanyard hole
Stainless steel hardware
Sheath:
(.080) Battle Drab Holstex Carbon Fiber sheath with black eyelets spaced to fit a large Tek-Lok. This sheath also has a drain hole and a new feature that allows for easy cleaning. The new design has a carbon fiber insert that can be removed. In doing so there is a large slot that can be used for spraying out and cleaning your sheath with easy! This sheath has great retention yet still shoots off with just a little push on the thumb ram!
Features:
The TG Scout EDC has several features that make it a great knife. 3/16" D2 steel 60 HRC blade, ergonomic G10 handle, sharpening notch, perfect swedge, rounded index finger choil, lanyard hole, two tone acid stonewash and a Holstex carbon fiber sheath.
Knife Specs:
Blade:
Thickness: 3/16"
Swedge
Handle:
Length: 4 1/2”
1/4" Lanyard hole
Sheath:
Features:
