Well this certainly appears like its a pro-Evenheat thread, thats for sure!
I guess I'll have to toss my two pennies in here about my Paragon.
I've got the Paragon 14" model, and its a very well-built and solid machine. Very heavy, was the first thing I noticed about it. The front-opening door was actually a feature that I liked about the oven becuase the counterweight keeps the door firmly-pressed against the opening... no need for a latch or handle.
The controller took a bit of a learning curve to get used to because I think Paragon just made the oven for knifemakers, but threw-together the instructional manual with all this generic stuff about cone-firing and all that crap. It kind of pissed me off that I had to spend a lot of time learning to program the darn thing to get what I wanted out of it.
The controller also falls short, imho, on a couple of things. For instance, programming the alarm is clunky and awkward. You certainly must be sure your programming steps are followed correctly, or the alarm will not sound. So here we have a condition in which the oven ramps up to a certain temperature setting with your blade inside. Great! Now how about letting it soak at the temp for a designated time? Okay then. The alarm (if you got it set right) will sound when you reach temp. Fine. Then you have to silence the alarm. Thats okay, but what about an alarm for when the soak is finished? I have to set a kitchen timer. :grumpy:
So all this just to do one heat cycle, and it requires a lot of attention. I cant just set it and an hour later go pull the blade out and quench it, or whatever. You would think that the $1400 I paid for it would have built-in some serious flexibility.
Now, I cant vouch for the Evenheat SetPro controllers, so dont know. I sincerely hope they are easier on the knifemaker than the Paragon, which are made by Sentry. Anyone here with some good resources and some electronic savvy could make an upgrade to either oven to be controlled via the PC, and be fully-controllable, i.e. rate of fire, soak times, ramping, and especially alarms and shutdowns at specified temps. Write up a comprehensive application and you've just made yourself some sweet cash, because you will probably sell a lot of them.
