- Oct 18, 2001
Any budding knifemakers out there?
******GIVEAWAY IS NOW OVER******
Winner announced here: http://www.bladeforums.com/forums/showpost.php?p=8304171&postcount=22
I'm asking this here in W&SS instead of ShopTalk where I KNOW there are a ton of "budding knifemakers" already.
Plus W&SS is a *COOLER* place to hang out.
I have a Bushcraft knife blank that I screwed up. The edge of the belt came loose and snagged the blade and ground away a bit of the edge. Since this is a Scandi Grind.....removing the notch would mean significantly raising the grind and thus makes it worthless to me as it no longer *looks new*...or like the 600+ others I have made.
So.....rather than throw it away (or throw it into the ceiling which is what I REALLY wanted to do...
).....I have ground out the notch and want to give it away to a *deserving newb* for FREE (I'll pick up s/h).
Must be in the USA.
When I was a *budding knifemaker* I read about other makers screwing up stuff and tossing it in the trash. Always made me wish I could "eat the crumbs from the table" so to speak....take the blade and finish it myself. I understood why most wouldn't allow it....it was their work, not mine. But since I sell these as unmarked blanks already, I figured it's no big deal to give away one that is not even a true blem. (I'm trying to rationalize this - help me out here...
Post what you're going to do with it - don't email me about it. I'll come back in a couple hours when the dust has settled and pick someone and send it off.
To sum up:
You will be getting a 2009 Bushcraft blank in CPM154 - fully heat-treated - with perfectly flat scandi grinds, finished flats, drilled tang...ready to glue up. I'll even toss in a pair of brass corby bolts if you ask nicely.
The only difference between this blank and the ones I sell for $80+s/h is that this one will have *slightly higher* grinds and, of course, it is FREE.
Sorry, no pics - use your imagination. www.kosterknives.com/pics
Thanks, guys
Dan
p.s. *deserving newb* => has never attempted making a knife of their own, has always wanted to, and has (or has access to) the necessary hand tools or power tools to do the job...and will actually do it (not shelf it).
Must be in the USA.
To sum up:
Thanks, guys
Dan
