savagesicslayer
- May 24, 2005
I've never tried it, but would sure love to see how someone fashions a square of tin foil into a cup.
Kinda like this.......
SAS Survival guide page 189.
More on that candle please. What do you do for the wick and to keep it from falling down in?
Badge54
The wick is just regular 1/8'' cotton candle wick.
I cut it an 1/8'' longer after it is bottomed out in the MRE Tabasco bottle. When you put the cap on, it pushes the wick down into the bottle and when you remove the cap, the wick pops out. No magic.
It doesn't fall into the bottle because of the neck. Even if it slid down a little, I can get the wick out with my SAK tweezers, but I have never in 20 plus years of doing this had any trouble with it stuck in the bottle. Even after sitting all capped up, the wick always came out more than I wanted it to. That's why I use tin foil to keep the flame lower.
Like I said, the tin foil will regulate the flame, and if you want the wick to really stick up, run a small piece of wire from your kit through the wick and across the neck of the bottle to hold it up. You will have a big flame at that point.
Before I put it in a tin or where ever I want it, I dip the cap in wax to seal it and to keep it from coming loose while it rides in the tin in my pocket. The caps are pretty tight and leak proof, but I don't want to take a chance.
I like carrying liquid candles more than wax candles because they not only burn longer, but I can use the fuel to start fires or even to make a large quick signal fire if you have a few ounces of fuel. You can cut open the candle and dump the fuel almost anywhere and on anything and start a signal fire FAST.
