- Jun 11, 2006
This is the second instalment of my tip of the day. Today’s tip involves safety.
So a little tip DO NOT, I repeat DO NOT have your small 120v mig welder plugged into the same circuit as the magnetic chuck on your surface grinder. ESPECIALLY when your running the surface grinder and you decide you will do some light fab work while you wait for the surface grinder to finish up. I was very lucky yesterday. I started welding and popped the breaker. I thankfully was just sparking out the D2 barstock. If I had been taking any kind of cut I would have created a 6 shot D2 flat stock shooter when I tripped that breaker. I’m lucky because my mag chuck stays magnetic to some extent after the power is switched off.
So when you plug in remember safety first.
