Chiro75 said:
I disagree. If you miss the bottle and dink it off the side of the blade, or hit it at a 50° angle instead of 90°, I fathom a guess that it will skew the results.
You should not do it when you have been drinking. Most people could conclude that if you miss the bottle you could ignore that trial, and if you go from 90 on one stab to 50 on another I suggest that you not play with sharp instruments in general, and make sure your forks have corks on the end of them in case you accidently poke your eye out during supper.
How feasible is it that you'll repeat the same motion consistently over and over and over again when you stab a bottle, walk to pick it up, place it again, walk back to where you think you were standing before, and repeat?
I check these things all the time as noted for example in the above on different days. The mean results are quite consistent, to the precision noted. I have large sample trials of such things as wood chopping for example which go to normal quickly even in such heavily influenced comparisons, it is the wonder of the normal distribution.
Of course if you really can't do this consistently it isn't quantitative for you, that doesn't mean that everyone has such wild behavior. It is something that of course the user would check themselves the same as any other work done to judge knives. As noted if you actually try to go in on a 90 and hit a 50 instead then no, it isn't for you.
If I'd designed an experiment with that many variables when I was a chem student in quantitative analysis I would've earned a big fat F!
In chemistry high precision is usually very important, one of my friends for example worked for years preparing standards which needed four decimal places in the concentration. Of course when comparing knives you don't need to work to this standard and thus you have to adjust methods accordingly. If I am measing flour for bread I don't use the same balance I would use to measure a solute for a standard solution.
If you are looking for performance differences in knives at a minimum then about 10% is sensible, trying to say performance differences exist at below this level really doesn't make much sense because the user will never see them. Now go back and look at how chemistry lab methods will be effected if all you had to do was get to within 10%, titrations could probably be done with beakers and graduated cylinders.
You can't look at method independently of the conclusions. You must first start off and ask what do I want to measure and now what tolerance do I want. Ok, now look at the random deviations and noting the square root N behavior of such influences, see what steps have to be taken to get the desired results. Your arguement is shown to be trivially false because if people were that uncoordinated they for example the Sharpmaker would never function.
Also, if this motion was so consistent and repeatable by humans, there would be no need to train in things like martial arts.
Again the goal is different, here you want extreme precision as well as automatic focus and pattern involvement. Watch old tapes of Mike Tyson boxing for example, he would routinely go into long chains of punches and body movement which you knew were almost instinct. You are not looking at the average effect here, you can't ask your opponent to stand still while you fire off a half a dozen punches because the average effect will be decent, if you get really sloppy once and drop your guard you probably won't get a second punch.
These tests rely on your skill level, which means they are not "quantitative" tests as the post suggests. In another 10 years with more wood chopping training, the tests will still be different.
Yes, this is why I noted you use a standard and recalibrate. You have to do this by the way with gauges and such in the lab, this doesn't mean they are not quantitative. Lots of things can cause calibrations to be off besides human interaction so this always has to be done periodically, even if you are just using machines.
Quantitative by the way just means being able to assign a number, it doesn't imply a particular precision. You can have quantitative measurements which just record order, this means you know the answer is closer to 10 than 100. papers are published with such precision.
-Cliff
