And that's how religious wars start...
[video=youtube;VxEkwUMyDUc]http://www.youtube.com/watch?v=VxEkwUMyDUc[/video]
When carrying in the right hand front pocket, clipped toward the side seam, tip up is the best and safest way to carry. Your hand will never go down on the blade side. Tip down it that position, you're fine going into the pocket but coming out if the tip is not completely nested between the scales you could catch the tip on your hand and...zzzzzzzzzip...OUCH.
Perhaps it's because I don't use assisted opening knives, but I've never had a knife open in my pocket.
This kind of discussion is bordering on a religious war. I have almost always carried tip-down and I usually refuse to buy a knife that isn't tip-down. I did carry a mini-grip for awhile and I noticed that for a small knife like that tip-up did work OK. But for a bigger knife it doesn't work. I have contended that people that carry tip-up are not telling us the whole story. I have fairly large hands and long fingers, and I typically wear tight jeans. When I carry a large knife tip-down and pull it out my thumb is right there on the thumb stud or thumb hole and I can open it right up. If I carry a large knife tip-up then when I pull it out my thumb is a long way from the thumb stud/hole and I have to do the inch-worm trick to get to the other end of the knife before I can open it. I would like for someone that carries a large knife tip-up to draw their knife slowly and describe where their hand is positioned on the knife and how far their thumb is from where it should be, or show how they got their thumb to where it should be.
From the experience I've had with older Benchmades, newer Benchmades, Spydercos, Kershaws and CRKT's, modern knives have stronger blade detents than older knives, and assisted knives have stronger detents than unassisted knives. My current assisted knives are the least likely of all of my knives to open accidentally. My older Benchmades and my newer Spydercos are the easiest to open.
When carrying in the right hand front pocket, clipped toward the side seam, tip up is the best and safest way to carry. Your hand will never go down on the blade side. Tip down it that position, you're fine going into the pocket but coming out if the tip is not completely nested between the scales you could catch the tip on your hand and...zzzzzzzzzip...OUCH. This risk is largely eliminated with a back lock style but I prefer tip down here.
For just about all other forms of clipped carry, like in a sleeve pocket, in a vest pocket, on Molle gear, you want that tip down so you don't put your hand down on that tip and catch it on the way down...plus you got gravity sort of holding it closed. Again, a risk mitigated by a back-lock or other lock with some spring action on the blade.
So I've oriented the clip on my Para-2 to tip up for what is my most common carry method, front right pocket clipped. I carry my Para-1 when I want a clipped knife in other orientations. Works out great. That's why makers really should make all their knives reversible...like the Para-2 or the Endura. There is a legion of people out there who'd give a kidney for a tip up Military...why not make one?
Pretty much this. There are supposedly to be safety issues associated with tip down but I haven't seen/experienced it yet. Also depends on how you like to draw the knife out.Tip up:
-Advantages: I like it
Tip Down:
-disadvantages: i don't like it
honestly its all personal preference, and most knives are made with 4 way clips anyhow.
