+1Many here on BF's like tip up due to the ease of deployment right out of the pocket. Tip up allows you to skip the step of repositioning the knife once taken out of the pocket. Also while tip up you could position your hand on the knife right as your hand enters the pocket.
I carry both ways and don't mind either. But I do find it a bit faster to set up for deployment while tip up.
I don't have a great preference for either, but in general I prefer tip down simply because if the knife should open slightly, the tip and edge aren't waiting to bite me if go to grab it.
If I did tip up on my delica 4, would I put the blade facing to the rear or front? Im right handed.
Tip-down is way faster to deploy.
Not true for knives bigger than the Delica :thumbdn:
Tip-down is way faster to deploy. You pinch the pivot area to pull the knife out of your pocket, pull up, use your middle-finger to get the knife's back to touch the palm of your hand, then deploy. No fumbling to get your thumb on the hole while in your pocket to deal with and tugging at the knife from the bottom and getting it stuck on your pocket lining (aka the pivot area when tip-up in the pocket).
