I remembered a few other things that really helped me out in addition to my first response. You can see in the single page link I posted how I like to pre-load the wrist to encourage a finer edge, but not spelled out directly is that I don't hold the knife as I would if I were going to use for a chore. The act of grinding an edge on a tool is totally different from using it to cut something, so a bit of experimentation might be in order to help find the most stable grip. I resisted this for a long time, but was instrumental in making a big leap in terms of consistency and ability to approach many different types of cutting tools with the same mechanical strategy. This is also a great reason to break the edge up into overlapping sections - makes it much easier to sharpen larger tools, or ones with a lot of belly etc.
Another tip is to "recalibrate" every so often by lowering the spine to gently hit the shoulder on whatever surface you're grinding with. The difference in tactile feedback is immediately apparent, and you can then elevate the spine till it just lets off. In this way you know you're working out from the shoulder, the angle isn't increasing, and generally will stay a lot more flat. Sometimes when I first start out on an edge that's badly worn, I'll lower the spine for a pass, elevate it for a pass, and now I have a good idea how much curvature the existing bevel has and at what range of pitch I'm working within. Makes for a quick judgement call on whether to change the inclusive angle at that stage. When working on a coarse abrasive, I can bump off the spine a couple times as I go and get a good idea how much more flat the bevel is becoming without stopping.
Feedback actually diminishes somewhat when one is right on the bevel but a new cutting edge hasn't formed yet - it will gradually increase subtly as the cutting edge forms and comes into good contact with the abrasive surface. When I cannot really lower the spine at all before hitting the shoulder, or raise it at all without feeling the edge catching, I know I'm pretty much done and have made a cutting bevel with very tight tolerance, at least as tight as I can achieve using tactile feedback. My only limit to accuracy is determined by the size of the abrasive, and it becomes more accurate as the abrasive size becomes smaller.
This can be done with Scandi or convex as well, but needs to be adapted a little to accommodate the difference in bevel curvature. You can still learn a lot about how much curvature is built into the convex by how much wiggle room you have moving the spine around. Keep in mind, this a recalibration method - 96% of your grinding should be on the target pitch with no shifting except for a few well-controlled passes to QC your angle control.
Here's the page in my manual where I bring it up.
https://app.box.com/s/nbuuqn1oa147nqsw6r67
