- Feb 3, 2010
so I'm still learning here and I know this will come with experience but the last couple blades I forged I ended up ruining the bevels when I tried to clean it up on the belt sander (currently using a 1"x30" but I'm looking into building a 2"x72"). I've made 2 small tantos 8"-10" and a small fixed blade utility blade and am having similar problems, uneven bevils. I'll get one side that looks great and the other side will end up having no definition.
I was reading in the stickeys about a magnetic bubble jig I could make to use with the belt grinder but all the links to the pictures are dead. obviously at this point its not just a grinding problem though, I need to get to the point where I can forge my bevels in more evenly on both sides, but eyeballing it is harder than I thought.
Would you recommend (as a beginner) doing more work by hand, using a file, or should I just get more practice in with the belt sander?
I'm also considering making a sen (draw knife for smoothing blades) since I've been making tantos but I've never seen one in action, just pictures. I might try making something like this: http://www.dfoggknives.com/photogallery/MakingSen/makingsen.htm
