Last summer I was getting used to all the different aspects of knifemaking. and this summer I am finally going to do a run of knives that I might give away to family members. I will be forging them as I have lots of rods left over. Only a little bit of W1 rod that is bigger than the 2 full size o1 rods that are not as thick. Im thinking that with forging , the o1 knives come thinned out at around 3/4 to an inch wide and not very thick , not much thicker than a chefs knife. so its not alot of material to work with. But the w1 is plenty for a more thick smaller knife. this is all of course without upsetting the rod.
What are some tips on how to make the knives as simple as possible? last year I had real issues trying grind a forged knife flat enough to seat scales properly for a full tang. It was frankly a nightmare with my flipped over belt sander. So should I go halftang? or "through" tang?
Another problem i had was pitting. Which I cannot seem to avoid with forging. But then I found that its likely because of my forge which is an Ebay forge that probly uses too much gas. So i used a charcoal forge i built out of bricks and it seemed like it helped with oxidation.
So should I get a nice wittlox forge with blower? I hate using coal so wood/charcoal would be my best bet economically.
Also what are some favorite normal woods to use that are not as expensive as the figured ones we like so much?
