kuraki
Fimbulvetr Knifeworks
- Jun 17, 2016
I spent the better part of the day yesterday working up two billets I was intending to be crushed Ws. Each billet was identical and were as follows:
1. 18 layers of 1075 and 15n20, 1075 layers were double layers, 8" x 1"
2. Weld and draw to about 10" long, then flipped on edge and drawn/ crushed to over 16" long.
3. Cut to 4x4" lengths stacked, welded and drawn out to about 10". At this point billets width has doubled to over 2"
4. Milled edges to clean and straight, cut both billets in 3" lengths and stacked both billets together, welded and drawn out to 12" or so.
After the welding and drawing in step one, all forging was done in the crushing direction.
Chopped the lapped end off and checked the pattern:
On the bottom left is exactly what I was shooting for, but on the right you can see how some of the layers just upset without crushing.
So two questions. Is there a technique to getting more crush, or is it simply that I need to restack more times? Second I was hoping my next step at this point would be ferry flipping, but unsure if I should add another step or two, to try and get a better pattern.
