I know this is anold thread but was curious about this topic after checking out the latest from ZT and noticed they"improved" my 560 model with a steel plate at the lock bar. After reading this and other threads I am beginning to think this is more a marketing gimmick to solve a non existing issue that may be more of a myth in the knife world than reality. I too cannot recall a single story of someones titanium frame lock failing from wear. Granted, I read usually specific issues that have less to do with this particular topic and have heard that Strider had issues but again no first person stories. It does seem logical that ti would grip the steel better and may explain why the ZT 200 with heavy duty steel liners could fail with mild spine whacks wheras their ti frame locks did not.
I too thought and still believe that a steel liner should be the stronger lock despite popular belief but this obviously depends on its execution, specifically, whether it stays rather than slides like the ZT 200. Why do I think this? As the fellow above stated , the scale supports the liner from flexing or bowing out for one. Secondly, the liner prevents most direct contact with ones hand grip which could possibly cause movement of the lock bar itself . Finally, just as a chain is only as strong as its weakest link so is a lock bar and all the ti lock bars I have seen are thinned out dramatically for ease of use whereas steel liners are not. Finally, I am quite confident that the quality steel is both stronger and tougher then even 6/4 Ti. For example, in the mountain bike world this hi end titanium is often used for lighter weight components such as after market pedal spindles but they are generally accepted to be for lightr weight racers and not heavier guys or freeriders, these guys stick with steel components. I am speaking of strength and toughness on a equal volume basis and not weight or items of equal size. My ti frame lock is no thicker than most steel liners. I guess one could argue that the ti frame lock is still thicker for a large portion and that it would be less likely to flex but then the steel liner is the same all the way and perhaps this helps spread the forces more evenly where the titanium would obviously concentrate that energy at the thick/thin transition creating a stress riser. Ugh, this is complicated. Ultimately, I still don't think a steel plate is needed for a ti frame lock.
