I just returned from a little trip and along with some other Titanium goodness...
... was able to score a nice little version of a Titanium Mini Vault Capsule on a Titanium neck chain. I was really impressed with this set in that it is ready to load up and go around the neck or remove the chain and put it on the keychain, turn it into a big zipper-pull, or hang it wherever... in that the large ring at the top of the cap is solid and does not appear to be able to bend open (it would need to break) or otherwise separate.
With the chain included it almost makes this an extra bonus.
This ENTIRE setup is satin Titanium except for the clear Silicone O-ring. The O-ring does not appear to be necessary in that the cap will screw down tightly without the O-ring in place but it probably helps to make it more water resistant with only a slight finger tight twist. The small retention chain makes it extremely difficult to lose the cap when it is removed.
As mentioned earlier, the capsule, clasp, chain ring, small retention chain, and all other rings are Titanium. The retention ring around the main body of the capsule and cap piece spins freely to avoid any binding. The cap is solid and the main section has a flat bottom.
The capsule exterior is 15mm wide and the interior is about 10mm wide. I have found that an AAA battery fits slightly loose. The exterior length is 50mm and the interior length appears to be approximately 40mm.
These come in a gift box that I neglected to photograph... Too busy sipping Sake from one of my Ti Tumblers...
NLA
The chain section (strictly speaking) is 58cm long and overall (including the clasp sections) it is just over 60cm long:
Next to my CR-2 Ion Titanium pocket light:
NLA
