- Jan 14, 2007
I'm not sure if this is the proper location for this but I figured if anyone can help it's you fellas.
I have a small folder with non caged bearings and it appears to me that the channel grooves in the Ti scales need to be about 1/32" deeper. Is there anyway to do this myself without having a CNC machine? I have dremals, drill presses, lots of patience and a steady hand. I do know those tolerances need to be perfect and this is probably a losing battle but I thought I'd ask. Knife is in $300 range, not cheap but willing to experiment with it. I am considering making a steel cutting tool that will bore a smooth circle and putting it in my drill press, clamp er down and get er done.
The reason I believe this is the case is the gap on the standoff side between scales is about 3/16" and opposite side (closure side) it's a fat 1/4". There are two standoffs in line and then the pivot is set in on center. So I feel that is all that could be causing that. Any suggestions would be appreciated. Yes I could send the knife back I'm sure and have it fixed but I like doing these things myself.
