Titanium Stand offs
Where can I get them. I am using 1/8 pivot pins on a couple of liner lock I am working on. Who is a good supplier for Ti standoffs with a 1/8 hole. Thanks in advance. I checked TKS, Midwest, knife kits, and,halpern titanium, any other ideas. Thanks in advance.
-frank
Sheffield Supply in Florida sells them. I'm not sure of the hole in the center. I've made them using 3/16" pivot barrels I had left over end cuts of. What I did was drill out the threads using a carbide 1/8" two flute drill from MSC and that allows them to sleeve fit over 1/8" pivot barrels. Looks like this but these are of course stainless not titanium. I have never seen ti sleeves available to use as stand offs but would sure like to.
STR
Those might work. I was since I already drilled and reamed the holes in the Ti liner to 1/8. The pivot pins are 1/8 in diameter and have a 2-56 pre tapped. I wanted to slide the pivot pin in through the stand off and tighten. I just confused my self.
I will check them out. Thanks.
-frank
