Titanium Tumblers & Mugs
Feedback: +8 / =0 / -0
I just returned from a little trip and have a few extra Double walled Titanium Tumblers (Small cups) available. These are either Titanium in the natural color (shiny to semi shiny) or an Oxide finish. This is what are available at this time:
This is the Double Walled Tumbler with a Coaster. Both are polished Titanium and the Coaster has engraved scrollwork on the surface. The Tumbler measures 100mm Tall, 55mm across the base, and 60mm across the interior upper edge. This one is $95.00 with shipping to the CONUS included. I have three available at this time.
Some multiple Titanium gear goodness
Cross Section:
A more elegant look:
I can accept paypal, Money Order, Cashiers Check, or regular check with clearance prior to shipment.
Best regards,
This is the Double Walled Tumbler with either a satin/polished Titanium surface or the Oxide finish that runs from a light green/gold to a darker green. The Tumbler measures 80mm Tall, 65mm across at the exterior base and upper edge. The inner edge of the lip has a beveled shape. This one is $38.00 with shipping to the CONUS included. I have three in satin finish and three in green available at this time.
These photos look more blue than the tumbler actually appears "in person"
The surface near the lip edge on these appears to be stressed from the construction. However, I have not found there to be any negative effect in function:
The apparent stress marks fade away from the lip edge:
Best regards,
I am back from another little trip...
There are several of the SATIN tumblers and one GREEN tumbler now available.
Three of the Tumbler/Coaster combinations are also now available.
**A question has been PM'd to me regarding capacity of these cups.
So to answer a good question in the thread as well as via PM...
The smaller cups hold exactly one full cup (with a slight bead above the rim) and comfortably 3/4 cup with a little room for drinking.
The cup with the coaster will comfortably hold one full cup and 1 1/4 cup just spills over a little.
Hope that helps and best regards,
Stuart
The smaller tumblers not only function perfectly with the more robust drinks... they also work VERY well for coffee or other hot beverages. Gives a classy touch to the morning or afternoon cup of java...
I have found that one packs away for use in the field as well. No more styrofoam or paper cups if I can avoid it.
There are four of the satin cups and three of the tumbler/coaster combinations available.
